Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2554.
Move thread dispatch disable check to legacy rtems_clock_tick(). Assert
that thread dispatching is disabled in _Watchdog_Tick(). This is
usually the case, since this function is called in interrupt context by
the clock tick service routine.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
