* | score: Add SMP support to _Watchdog_Report_chain() | Sebastian Huber | 2013-08-27 | 1 | -1/+3 |
* | score: Create watchdog implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of watchdog.h and watchdog.inl into new header file watchdogimpl.h. The watchdog.h contains now only the application visible API. | ||||
* | score misc: Score misc: Clean up Doxygen #5 | Alex Ivanov | 2012-11-29 | 1 | -2/+3 |
* | 2010-11-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-25 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | * libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c, posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl, score/inline/rtems/score/watchdog.inl, score/src/apiext.c, score/src/chain.c, score/src/coremsgflushsupp.c, score/src/coremsginsert.c, score/src/objectshrinkinformation.c, score/src/schedulerpriorityyield.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c, score/src/userextthreadbegin.c, score/src/userextthreadcreate.c, score/src/userextthreaddelete.c, score/src/userextthreadrestart.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c, score/src/watchdogreportchain.c: Avoid chain API violations. | ||||
* | 2008-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-26 | 1 | -0/+50 |
* score/Makefile.am, score/include/rtems/score/watchdog.h: Add _Watchdog_Report and _Watchdog_Report_chain as debug assist routines. They are NOT to be used in directives. * score/src/watchdogreport.c, score/src/watchdogreportchain.c: New files. |
