Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
application visible API.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
* score/src/watchdognanoseconds.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/watchdog.h, score/src/coretodget.c,
score/src/coretodgetuptime.c: Do not allow NULL as nanoseconds since
last tick handler pointer.
