The use of a hand crafted lock for Per_CPU_Control::Lock was necessary
at some point in the SMP support development, but it is no longer
justified.
Update #3706
Add a lock and use a chain iterator for safe iteration during concurrent
user extension addition and removal.
Ensure that dynamically added thread delete and fatal extensions are
called in reverse order.
Update #2555.
Update #2692.
The rtems_extension_create() no longer uses the Giant lock. Ensure that
we call _User_extensions_Add_set() only in the right context.
Update #2555.
Add and use _Per_CPU_Release_all().
The context switch user extensions are invoked in _Thread_Dispatch().
This change is necessary to avoid the giant lock in _Thread_Dispatch().
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/extensioncreate.c,
sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h,
score/src/userextthreaddelete.c, score/src/userext.c,
score/src/userextthreadcreate.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextaddset.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/userextthreadrestart.c: Documentation. The types
User_extensions_routine and rtems_extension are now deprecated.
Removed unused types User_extensions_thread_post_switch_extension and
rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set()
in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in
_User_extensions_Add_set_with_table().
* score/src/userextaddapiset.c: Removed file.
* score/Makefile.am: Update.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c,
sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/include/rtems/score/userext.h, score/src/chain.c,
score/src/userext.c: Switch to newlib reentrancy extension being
installed in the initial set instead of using rtems_extension_create.
While implementing this, noticed that user extensions and chain code
had multiple functions in a single file which is not desirable in the
SuperCore and API portions of RTEMS, so split these into multiple
files with one function per file. Also noticed that some of user
extension code was inlined for no particular reason so moved that to
C bodies. Split executive shutdown from initialization since not
every application shuts down. Moved __fini call to executive shutdown
to be more symmetrical with where it is called at startup.
* sapi/src/exshutdown.c, score/src/chainappend.c,
score/src/chainextract.c, score/src/chainget.c,
score/src/chaininsert.c, score/src/userextaddapiset.c,
score/src/userextaddset.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New
files.
* score/inline/rtems/score/userext.inl: Removed.
