* | userext: Simplify configuration | Sebastian Huber | 2019-12-09 | 1 | -13/+7 |
| | | | | | Avoid the use of the workspace and use statically allocated switch controls for the initial extensions. | ||||
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -1/+1 |
| | | | | Update #3706 | ||||
* | score: Fix for RTEMS_DEBUG | Sebastian Huber | 2016-07-22 | 1 | -0/+1 |
* | score: _User_extensions_Handler_initialization() | Sebastian Huber | 2016-04-18 | 1 | -28/+23 |
| | | | | Simplify _User_extensions_Handler_initialization(). | ||||
* | Optional Initial Extensions initialization | Sebastian Huber | 2016-02-03 | 1 | -15/+8 |
| | | | | Update #2408. | ||||
* | score: Add and use <rtems/score/userextimpl.h> | Sebastian Huber | 2012-11-22 | 1 | -1/+1 |
| | | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation. | ||||
* | score: Statically initialize user extensions | Sebastian Huber | 2012-11-13 | 1 | -26/+33 |
| | | | | | | | | | The initial extensions remain now in a read-only table and will not be copied to work space memory. The extension chains are statically initialized. This makes it possible to call _User_extensions_Iterate() independent of the system state. It is now guaranteed that the fatal callout of the initial extensions will be called provided the stack pointer, the read-only data, and code memory are valid. | ||||
* | sapi: Make initial user extensions table read-only | Sebastian Huber | 2012-11-07 | 1 | -4/+4 |
* | sapi: Use rtems_*_get_number_of_initial_extensions | Sebastian Huber | 2012-11-07 | 1 | -1/+1 |
* | sapi: Use rtems_config*_get_user_extension_table | Sebastian Huber | 2012-11-07 | 1 | -1/+1 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -2/+2 |
* | 2009-09-25 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-09-25 | 1 | -5/+9 |
| | | | | | | | | | | | | | | | | | | * sapi/include/rtems/extension.h, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/extensioncreate.c, sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h, score/src/userextthreaddelete.c, score/src/userext.c, score/src/userextthreadcreate.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextaddset.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c, score/src/userextthreadrestart.c: Documentation. The types User_extensions_routine and rtems_extension are now deprecated. Removed unused types User_extensions_thread_post_switch_extension and rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set() in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in _User_extensions_Add_set_with_table(). * score/src/userextaddapiset.c: Removed file. * score/Makefile.am: Update. | ||||
* | 2008-12-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-17 | 1 | -5/+8 |
| | | | | | | | | | | | | | * sapi/include/rtems/extension.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c, score/include/rtems/score/mpci.h, score/include/rtems/score/object.h, score/include/rtems/score/thread.h, score/include/rtems/score/tod.h, score/include/rtems/score/userext.h, score/include/rtems/score/wkspace.h, score/src/coretod.c, score/src/mpci.c, score/src/object.c, score/src/thread.c, score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and SuperCore Handler initialization routines to directly pull parameters from configuration table. | ||||
* | 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-09 | 1 | -177/+26 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c, sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/userext.h, score/src/chain.c, score/src/userext.c: Switch to newlib reentrancy extension being installed in the initial set instead of using rtems_extension_create. While implementing this, noticed that user extensions and chain code had multiple functions in a single file which is not desirable in the SuperCore and API portions of RTEMS, so split these into multiple files with one function per file. Also noticed that some of user extension code was inlined for no particular reason so moved that to C bodies. Split executive shutdown from initialization since not every application shuts down. Moved __fini call to executive shutdown to be more symmetrical with where it is called at startup. * sapi/src/exshutdown.c, score/src/chainappend.c, score/src/chainextract.c, score/src/chainget.c, score/src/chaininsert.c, score/src/userextaddapiset.c, score/src/userextaddset.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextthreadcreate.c, score/src/userextthreaddelete.c, score/src/userextthreadrestart.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New files. * score/inline/rtems/score/userext.inl: Removed. | ||||
* | Include config.h. | Ralf Corsepius | 2005-01-27 | 1 | -0/+4 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-17 | 1 | -32/+32 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -2/+0 |
* | 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types. | ||||
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -1/+1 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -27/+29 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | new file -- split from inlines | Joel Sherrill | 1995-08-29 | 1 | -0/+202 |
