comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
PR 1914/cpukit
* score/src/timespecgreaterthan.c, score/src/ts64greaterthan.c:
Removed files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64divide.c, score/src/ts64dividebyinteger.c,
score/src/ts64equalto.c, score/src/ts64getnanoseconds.c,
score/src/ts64getseconds.c, score/src/ts64lessthan.c,
score/src/ts64set.c, score/src/ts64settozero.c,
score/src/ts64subtract.c, score/src/ts64toticks.c,
score/src/ts64totimespec.c: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
CPU_TIMESTAMP_USE_INT64, and CPU_TIMESTAMP_USE_INT64_INLINE. Removed
copy and paste.
* score/Makefile.am, score/preinstall.am,
score/include/rtems/score/timestamp.h: Add 64-bit implementation of
SuperCore Timestamps. Tested on PowerPC/psim and SPARC/sis.
* score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64getseconds.c, score/src/ts64greaterthan.c,
score/src/ts64lessthan.c, score/src/ts64set.c,
score/src/ts64settozero.c, score/src/ts64subtract.c,
score/src/ts64toticks.c, score/src/ts64totimespec.c: New files.
