path: root/cpukit/score/src/timespectoticks.c (follow)
* score: Rename tod.h to todimpl.hSebastian Huber2013-08-011-1/+1
* score: Merge tod implementation into one fileSebastian Huber2013-07-261-5/+1
| | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS().
* 2011-09-01 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-09-011-6/+12
| | | | | | | PR 1895/cpukit * score/src/coretodmsecstoticks.c, score/src/coretodusectoticks.c, score/src/timespectoticks.c: Ensure time conversions to ticks do not ignore partial tick and return 1 less than desired.
* Whitespace removal.Ralf Corsepius2009-11-291-2/+2
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-161-3/+4
| | | | | | | | | | * libcsupport/src/__times.c, posix/src/adjtime.c, posix/src/clockgetres.c, posix/src/sysconf.c, rtems/src/clockgettickspersecond.c, rtems/src/clockgettod.c, rtems/src/clockset.c, rtems/src/clocktodvalidate.c, score/src/timespecfromticks.c, score/src/timespectoticks.c, score/src/ts64toticks.c: More case converted to use configuration table entry not _TOD_Microseconds_per_tick.
* 2007-04-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-051-0/+49
* posix/Makefile.am, posix/include/rtems/posix/time.h, posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c, posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c, posix/src/pthread.c, posix/src/pthreadcreate.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/semtimedwait.c, posix/src/sigtimedwait.c, posix/src/ualarm.c, rtems/src/clocktodtoseconds.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodget.c, score/src/coretodgetuptime.c, score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec manipulation routines in the SuperCore. Use them everywhere possible. This lead to significant cleanup in the API routines and eliminated some of the same code from the POSIX API. At this point, the SuperCore keeps time in POSIX timespec format properly from 1970. You just cannot set it before 1988 in keeping with RTEMS traditional behavior. * score/include/rtems/score/timespec.h, score/src/timespecaddto.c, score/src/timespecfromticks.c, score/src/timespecisvalid.c, score/src/timespeclessthan.c, score/src/timespecsubtract.c, score/src/timespectoticks.c: New files. * posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c: Removed.
