* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -1/+6 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | Remove explicit file names from @file | Sebastian Huber | 2019-02-28 | 1 | -1/+1 |
| | | | | | | This makes the @file documentation independent of the actual file name. Update #3707. | ||||
* | score: Rename tod.h to todimpl.h | Sebastian Huber | 2013-08-01 | 1 | -1/+1 |
* | score: Merge tod implementation into one file | Sebastian Huber | 2013-07-26 | 1 | -5/+1 |
| | | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | ||||
* | 2011-09-01 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-09-01 | 1 | -6/+12 |
| | | | | | | | PR 1895/cpukit * score/src/coretodmsecstoticks.c, score/src/coretodusectoticks.c, score/src/timespectoticks.c: Ensure time conversions to ticks do not ignore partial tick and return 1 less than desired. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -2/+2 |
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 1 | -3/+4 |
| | | | | | | | | | | * libcsupport/src/__times.c, posix/src/adjtime.c, posix/src/clockgetres.c, posix/src/sysconf.c, rtems/src/clockgettickspersecond.c, rtems/src/clockgettod.c, rtems/src/clockset.c, rtems/src/clocktodvalidate.c, score/src/timespecfromticks.c, score/src/timespectoticks.c, score/src/ts64toticks.c: More case converted to use configuration table entry not _TOD_Microseconds_per_tick. | ||||
* | 2007-04-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-05 | 1 | -0/+49 |
* posix/Makefile.am, posix/include/rtems/posix/time.h, posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c, posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c, posix/src/pthread.c, posix/src/pthreadcreate.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/semtimedwait.c, posix/src/sigtimedwait.c, posix/src/ualarm.c, rtems/src/clocktodtoseconds.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodget.c, score/src/coretodgetuptime.c, score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec manipulation routines in the SuperCore. Use them everywhere possible. This lead to significant cleanup in the API routines and eliminated some of the same code from the POSIX API. At this point, the SuperCore keeps time in POSIX timespec format properly from 1970. You just cannot set it before 1988 in keeping with RTEMS traditional behavior. * score/include/rtems/score/timespec.h, score/src/timespecaddto.c, score/src/timespecfromticks.c, score/src/timespecisvalid.c, score/src/timespeclessthan.c, score/src/timespecsubtract.c, score/src/timespectoticks.c: New files. * posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c: Removed. |
