path: root/cpukit/score/src/timespecdividebyinteger.c (follow)
* score misc: Clean up Doxygen #2 (GCI 2012)Christopher Kerl2012-11-281-1/+5
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* Whitespace removal.Ralf Corsepius2009-11-291-1/+1
* 2009-11-10 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2009-11-101-1/+2
| | | | | | PR 1468/cpukit * score/src/timespecdividebyinteger.c: Rework statement to ensure 64-bit multiplication is used.
* 2007-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-171-0/+52
* ChangeLog, configure.ac, libcsupport/src/__times.c, libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/thread.h, score/include/rtems/score/timespec.h, score/src/threaddispatch.c, score/src/threadinitialize.c, score/src/threadtickletimeslice.c, score/src/timespecdivide.c: Add nanoseconds granularity to the rate monotonic period statistics and CPU usage statistics. This capability is enabled by default although may be conditionally disabled by the user. It could be too much overhead on small targets but it does not appear to be bad in early testing. Its impact on code size has not been evaluated either. It is possible that both forms of statistics gathering could be disabled with further tweaking of the conditional compilation. * score/src/timespecdividebyinteger.c: New file.
