Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
The new Simple SMP Scheduler allocates a processor for the processor
count highest priority ready threads. The thread priority and position
in the ready chain are the only information to determine the scheduling
decision. Threads with an allocated processor are in the scheduled
chain. After initialization the scheduled chain has exactly processor
count nodes. Each processor has exactly one allocated thread after
initialization. All enqueue and extract operations may exchange threads
with the scheduled chain. One thread will be added and another will be
removed. The scheduled and ready chain is ordered according to the
thread priority order. The chain insert operations are O(count of ready
threads), thus this scheduler is unsuitable for most real-time
applications.
The thread preempt mode will be ignored.
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
PR 1921/cpukit
* score/inline/rtems/score/thread.inl,
score/src/threadstartmultitasking.c: Allow CPU port to provide
optional multitasking start and stop.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
PR 1599/cpukit
* posix/src/psignalunblockthread.c, posix/src/pthreadkill.c,
rtems/src/signalsend.c, score/include/rtems/score/percpu.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetstate.c,
score/src/threadyieldprocessor.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
* libcsupport/src/malloc_initialize.c, sapi/src/exinit.c,
score/src/threadstartmultitasking.c: Fix spacing.
* libmisc/stackchk/check.c: Move variable into compiler specific conditional.
* sapi/src/exinit.c, score/src/threadstartmultitasking.c: Improve
comments.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
split into one function per file, this will decrease the size of executables.
