path: root/cpukit/score/src/threadstackfree.c (follow)
* score: Simplify thread stack freeSebastian Huber2020-02-121-25/+7
| | | | Update #3835.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Create thread implementation headerSebastian Huber2013-07-261-11/+1
| | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files.
* score: Merge sysstate API into one fileSebastian Huber2013-07-241-1/+0
* score misc: Score misc: Clean up Doxygen #5Alex Ivanov2012-11-291-9/+7
* score: Add and use <rtems/score/userextimpl.h>Sebastian Huber2012-11-221-1/+0
| | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation.
* 2011-12-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-141-4/+4
| | | | | | | | | | | | PR 1924/cpukit * sapi/include/rtems/config.h: Added stack_allocate_init_hook to rtems_configuration_table. * sapi/include/confdefs.h: Added CONFIGURE_TASK_STACK_FROM_ALLOCATOR and CONFIGURE_TASK_STACK_ALLOCATOR_INIT defines. Set default stack allocator and free hook to _Workspace_Allocate() and _Workspace_Free() respectively. * score/src/thread.c, score/src/threadstackallocate.c, score/src/threadstackfree.c: Update due to API changes.
* 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-01-281-1/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h, score/cpu/i386/rtems/score/idtr.h, score/cpu/powerpc/rtems/powerpc/registers.h, score/src/objectidtoname.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadcreateidle.c, score/src/threaddelayended.c, score/src/threaddispatch.c, score/src/threadget.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadready.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/threadstart.c, score/src/threadstartmultitasking.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c: Fix typo where license said found in found in.
* 2009-09-13 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-131-12/+11
| | | | | | * score/include/rtems/score/thread.h, score/src/threadinitialize.c, score/src/threadstackfree.c: Disable capability for API to let user provide thread stack when no API configured includes this capability.
* 2008-12-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-151-3/+3
| | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/itronapi.h, libmisc/capture/capture.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-mpci.c, posix/include/rtems/posix/config.h, posix/include/rtems/posix/posixapi.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/src/taskinitusers.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/src/exinit.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/isr.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/wkspace.c: Eliminate pointers to API configuration tables in the main configuration table. Reference the main configuration table and the API configuration tables directly using the confdefs.h version rather than obtaining a pointer to it. This eliminated some variables, a potential fatal error, some unnecessary default configuration structures. Overall, about a 4.5% reduction in the code size for minimum and hello on the SPARC.
* 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-031-2/+5
| | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/malloc.c, libmisc/monitor/mon-command.c, posix/preinstall.am, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c, posix/src/mutexdestroy.c, posix/src/mutexinit.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/init.h, sapi/include/rtems/sptables.h, sapi/src/exinit.c, score/include/rtems/system.h, score/include/rtems/score/mpci.h, score/src/mpci.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/wkspace.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred.
* Include config.h.Ralf Corsepius2005-01-271-0/+4
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-171-0/+57
split into one function per file, this will decrease the size of executables.
