Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
* rtems/include/rtems/rtems/event.h,
rtems/inline/rtems/rtems/eventset.inl, rtems/src/event.c,
rtems/src/eventseize.c, rtems/src/eventsurrender.c,
rtems/src/eventtimeout.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/interr.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/tqdata.h,
score/inline/rtems/score/threadq.inl,
score/inline/rtems/score/tqdata.inl, score/src/threadq.c,
score/src/threadqtimeout.c: Refactor thread queue enqueue and event
blocking synchronization critical sections. This resulted in three
copies of essentially the same hard to test critical section code
becoming the one shared routine _Thread_blocking_operation_Cancel. In
addition, the thread queue and event code now share a common
synchronization enumerated type. Along the way, switches were
reworked to eliminate dead code generated by gcc and comments and
copyrights were updated.
* score/include/rtems/score/threadsync.h,
score/src/threadblockingoperationcancel.c: New files.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
