application visible API.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
* rtems/include/rtems/rtems/event.h,
rtems/inline/rtems/rtems/eventset.inl, rtems/src/event.c,
rtems/src/eventseize.c, rtems/src/eventsurrender.c,
rtems/src/eventtimeout.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/interr.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/tqdata.h,
score/inline/rtems/score/threadq.inl,
score/inline/rtems/score/tqdata.inl, score/src/threadq.c,
score/src/threadqtimeout.c: Refactor thread queue enqueue and event
blocking synchronization critical sections. This resulted in three
copies of essentially the same hard to test critical section code
becoming the one shared routine _Thread_blocking_operation_Cancel. In
addition, the thread queue and event code now share a common
synchronization enumerated type. Along the way, switches were
reworked to eliminate dead code generated by gcc and comments and
copyrights were updated.
* score/include/rtems/score/threadsync.h,
score/src/threadblockingoperationcancel.c: New files.
* score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/coremutex.c, score/src/coremutexflush.c,
score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c,
score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c, score/src/heap.c,
score/src/heapallocate.c, score/src/heapextend.c,
score/src/heapfree.c, score/src/heapsizeofuserarea.c,
score/src/interr.c, score/src/iterateoverthreads.c,
score/src/mpci.c, score/src/object.c, score/src/objectallocate.c,
score/src/objectallocatebyindex.c, score/src/objectclearname.c,
score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c,
score/src/objectget.c, score/src/objectgetbyindex.c,
score/src/objectgetisr.c, score/src/objectgetnoprotection.c,
score/src/objectidtoname.c, score/src/objectinitializeinformation.c,
score/src/objectmp.c, score/src/objectnametoid.c,
score/src/objectshrinkinformation.c, score/src/thread.c,
score/src/threadcreateidle.c, score/src/threadget.c,
score/src/threadidlebody.c, score/src/threadinitialize.c,
score/src/threadqfirstpriority.c, score/src/threadqflush.c,
score/src/threadreset.c, score/src/threadrestart.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstart.c, score/src/userext.c,
score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using
c99 fixed size types.
