comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
* score/src/corebarrier.c, score/src/corebarrierrelease.c,
score/src/corebarrierwait.c, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgclose.c,
score/src/coremsgflush.c, score/src/coremsgflushsupp.c,
score/src/coremsgflushwait.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c,
score/src/corerwlock.c, score/src/coresem.c,
score/src/coresemflush.c, score/src/coresemseize.c,
score/src/threadblockingoperationcancel.c,
score/src/threadqenqueue.c: Remove unnecessary include of mpci.h.
* rtems/include/rtems/rtems/event.h,
rtems/inline/rtems/rtems/eventset.inl, rtems/src/event.c,
rtems/src/eventseize.c, rtems/src/eventsurrender.c,
rtems/src/eventtimeout.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/interr.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/tqdata.h,
score/inline/rtems/score/threadq.inl,
score/inline/rtems/score/tqdata.inl, score/src/threadq.c,
score/src/threadqtimeout.c: Refactor thread queue enqueue and event
blocking synchronization critical sections. This resulted in three
copies of essentially the same hard to test critical section code
becoming the one shared routine _Thread_blocking_operation_Cancel. In
addition, the thread queue and event code now share a common
synchronization enumerated type. Along the way, switches were
reworked to eliminate dead code generated by gcc and comments and
copyrights were updated.
* score/include/rtems/score/threadsync.h,
score/src/threadblockingoperationcancel.c: New files.
PR 1222/cpukit
* score/Makefile.am, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl, score/src/coremsgsubmit.c,
score/src/coremutexsurrender.c, score/src/threadchangepriority.c,
score/src/threadclearstate.c, score/src/threadhandler.c,
score/src/threadinitialize.c, score/src/threadqdequeuefifo.c,
score/src/threadqextractfifo.c, score/src/threadqextractpriority.c,
score/src/threadsetstate.c: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* score/src/threadqrequeue.c: New file.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
PR 1124/rtems
* score/include/rtems/score/threadq.h, score/src/coremutexseize.c,
score/src/coremutexsurrender.c, score/src/threadqenqueue.c,
score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c:
The placement of the changing a thread's priority when using priority
ceiling should be on the successful transfer of the mutex -- not when
the thread tries to acquire. Plus the lack of a dispatch disable
point lead to the potential for a thread timing out and already
having inherited the ceiling priority.
Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru>
* score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/inline/rtems/score/threadmp.inl,
score/macros/rtems/score/threadmp.inl, score/src/threadmp.c,
score/src/threadqenqueue.c: Victor spotted the problem that
_MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate
variables and needed to be set to the same value. I took that
idea and just removed _Thread_MP_Receive. All uses are now
_MPCI_Receive_server_tcb.
