Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Use a per-CPU thread dispatch disable level. So instead of one global
thread dispatch disable level we have now one instance per processor.
This is a major performance improvement for SMP. On non-SMP
configurations this may simplifiy the interrupt entry/exit code.
The giant lock is still present, but it is now decoupled from the thread
dispatching in _Thread_Dispatch(), _Thread_Handler(),
_Thread_Restart_self() and the interrupt entry/exit. Access to the
giant lock is now available via _Giant_Acquire() and _Giant_Release().
The giant lock is still implicitly acquired via
_Thread_Dispatch_decrement_disable_level().
The giant lock is only acquired for high-level operations in interrupt
handlers (e.g. release of a semaphore, sending of an event).
As a side-effect this change fixes the lost thread dispatch necessary
indication bug in _Thread_Dispatch().
A per-CPU thread dispatch disable level greatly simplifies the SMP
support for the interrupt entry/exit code since no spin locks have to be
acquired in this area. It is only necessary to get the current
processor index and use this to calculate the address of the own per-CPU
control. This reduces the interrupt latency considerably.
All elements for the interrupt entry/exit code are now part of the
Per_CPU_Control structure: thread dispatch disable level, ISR nest level
and thread dispatch necessary. Nothing else is required (except CPU
port specific stuff like on SPARC).
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* src/threadloadenv.c: Removed warnings.
split into one function per file, this will decrease the size of executables.
