Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
Do not assume that the scheduler selects the main processor for the
initialization thread.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* score/src/threadhandler.c: Don't undefine __USE_INIT_FINI__ for
the avr.
PR 1901/cpukit
* score/src/threadhandler.c: Do not use internal tasks for global
initialization in MP configuration.
* include/rtems/userenv.h, score/src/threadhandler.c: Formatting.
* sapi/src/exshutdown.c: Add comments.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added
init/fini array support for ARM EABI. The __libc_init_array() and
__libc_fini_array() functions are provided by Newlib.
PR 1796/cpukit
* sapi/src/exshutdown.c, score/include/rtems/score/percpu.h,
score/include/rtems/score/smp.h, score/src/smp.c,
score/src/threaddispatch.c, score/src/threadhandler.c: Added SMP
interprocess communications.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Revert
previous commit due to too many broken linker command files. The
HAVE_INITFINI_ARRAY is defined for nearly all targets by Newlib, but
only few linker command files respect this.
support for .preinit_array, .init_array and .fini_array sections.
* score/src/threadhandler.c: Remove comment mentioning unix port.
* score/include/rtems/score/thread.h, score/src/threadhandler.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Disable thread protocol and scheduling capabilities not exercised
when POSIX or ITRON API is disabled.
* score/include/rtems/score/thread.h, score/src/threadhandler.c: Merge
conditional code from main and init/fini C++ constructors so the body
of this method reads better. Mark thread prototypes which are not
currently exercised by any APIs with
FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API conditional.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Do not
think about running init/fini on AVR. We do not know what mechanism
it uses but this is not it.
* score/src/threadhandler.c: M32R uses different name for init.
* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Call
fini() as part of exit(). This avoids atexit() being a required
function.
* rtems/include/rtems/rtems/message.h, sapi/include/confdefs.h,
score/src/coresemseize.c, score/src/threadhandler.c: Comment
improvements from class.
* score/src/threadhandler.c, sapi/src/exshutdown.c:
cannot call _fini via atexit() from rtems_shutdown_executive()
because at the point where rtems_shutdown_executive is called
the C-library is already dead.
Instead, register an atexit(_fini) after calling _init().
* score/cpu/sparc/cpu.c, score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/context.h, score/src/threadhandler.c: Fix
stack so gdb backtrace does not print corrupted frame message after
_Thread_Handler. Daniel Hellstrom <daniel@gaisler.com> provided the
SPARC implementation and I made it more general.
* rtems/include/rtems/rtems/clock.h, score/src/threadhandler.c: Fix
spacing and spelling.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
PR 1222/cpukit
* score/Makefile.am, score/include/rtems/score/coremutex.h,
score/include/rtems/score/threadq.h,
score/inline/rtems/score/coremutex.inl, score/src/coremsgsubmit.c,
score/src/coremutexsurrender.c, score/src/threadchangepriority.c,
score/src/threadclearstate.c, score/src/threadhandler.c,
score/src/threadinitialize.c, score/src/threadqdequeuefifo.c,
score/src/threadqextractfifo.c, score/src/threadqextractpriority.c,
score/src/threadsetstate.c: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* score/src/threadqrequeue.c: New file.
PR 761/rtems
* score/src/threadhandler.c: Add volatile cast so test is weak function
is present will do something. Otherwise, it can be assume by gcc to
always be a true condition.
PR 356/bsps
* src/threadhandlerc: This patch makes RTEMS/PowerPC eabi compliant.
Let Thread_Handler verify that _init/_main are non-NULL
before calling them (gives the linker script/user more
freedom to handle special cases).
* src/threadhandler.c: Prototype _init() and _main() if they are needed
to avoid a warning.
* src/threaddispatch.c, src/threadhandler.c: Per PR211 fix
saving/restoring floating point context. The fpsave and fprestore
routines are only used in a executing context which _is_ fp and hence
has the FPU enabled. The current behavior required the FPU always to
be on which is very dangerous if lazy context switching is used.
[Joel Note: Some ports explicitly enabled the FPU in the FP save and
restore routines to avoid this.]
The patch also makes sure (on powerpc only) that the FPU is disabled
for integer tasks. Note that this is crucial if deferred fp context
switching is used. Otherwise, fp context corruption may go undetected!
Also note that even tasks which merely push/pop FP registers to/from
the stack without modifying them still MUST be FP tasks - otherwise
(if lazy FP context switching is used), FP register corruption (of
other, FP, tasks may occur)!
Furthermore, (on PPC) by default, lazy FP context save/restore
is _disabled_.
* src/threadhandler.c: When __USE__MAIN__ is defined by the toolset,
invoke the global constructors via __main. Reported as tested by
Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov
<vvv@oktet.ru> in conjunction with a new set of tool RPMs
(gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
* src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* src/threadhandler.c: Now process C++ global constructors
(_init) as part of the first task execution not in BSP space.
This depends on the toolset defining USE_INIT_FINI so you
have to have the right toolset version.
support for return codes from POSIX threads that do an implicit exit
by returning from the bottom of the main function.
split into one function per file, this will decrease the size of executables.
