path: root/cpukit/score/src/threadget.c (follow)
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-10/+21
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/Makefile.am, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/object.h, include/rtems/score/threadq.h, inline/rtems/score/object.inl, inline/rtems/score/thread.inl, macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c, src/coremutex.c, src/coresem.c, src/mpci.c, src/objectcomparenameraw.c, src/objectextendinformation.c, src/objectinitializeinformation.c, src/objectnametoid.c, src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c, src/threadqextractwithproxy.c: Modified as part of above. * include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New files.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-171-0/+73
split into one function per file, this will decrease the size of executables.
