* | score misc: Clean up Doxygen (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -1/+7 |
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208 | ||||
* | 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.com | Jennifer Averett | 2011-04-21 | 1 | -0/+54 |
PR 1777/cpukit * libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c, score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c, score/include/rtems/score/coremutex.h, score/include/rtems/score/thread.h, score/inline/rtems/score/thread.inl, score/src/heapfree.c, score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c: Consolidated access to _Thread_Dispatch_disable_level. * score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c: New files. |
