path: root/cpukit/score/src/thread.c (follow)
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-0/+2
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Thread Handler split into multiple files. Eventually, as RTEMS isJoel Sherrill1999-05-171-1304/+0
| | | | split into one function per file, this will decrease the size of executables.
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-0/+2
| | | | it work.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-11-191-0/+8
| | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP.
* IDLE task stack size now specified as a field in the CPU Table for allJoel Sherrill1998-09-231-2/+7
| | | | ports.
* Ralf Corsepius noted that there was a dead path in _Thread_Initialize.Joel Sherrill1998-02-181-6/+2
* Added support for context switching the data used by the gcc m68kJoel Sherrill1997-05-281-1/+1
| | | | | | software floating point emulation code. Code implemented by Karen Sara Looney <Karen.Looney@colorado.edu> with much email assistance from Joel.
* added support for tracking thread cpu usage.Joel Sherrill1997-04-091-0/+2
* Modified calls to _Thread_Change_priority to take a third argument. The newJoel Sherrill1997-03-081-3/+30
| | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority.
* added some casts to reduce warnings reported by users with Microtec C++Joel Sherrill1997-01-081-10/+14
| | | | compiler.
* added support for cpu time used field in tcbJoel Sherrill1996-10-151-0/+16
* _Thread_Start_multitasking: added code to initialize the floating pointJoel Sherrill1996-08-151-1/+25
| | | | context of the first thread to execute.
* Added code so post context switch extensions can be run on every contextJoel Sherrill1996-06-131-2/+5
| | | | switch. This was needed to support process wide signals.
* added code to _Thread_Clear_state to check if the state was not currently set.Joel Sherrill1996-06-101-13/+19
* Added Sporadic Server support to posix threads which required changesJoel Sherrill1996-06-061-26/+49
| | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize.
* added cpu_time_budget field to Thread_Control and removed the global variableJoel Sherrill1996-06-051-4/+3
| | | | _Thread_Ticks_remaining_in_timeslice.
* fixed spacingJoel Sherrill1996-06-051-1/+1
* added support for the api providing the thread stack areaJoel Sherrill1996-06-051-23/+33
* changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler.Joel Sherrill1996-05-281-1/+1
| | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level.
* invoke thread stack free routine instead of Workspace free.Joel Sherrill1996-05-231-2/+26
* added comment regarding stack alignment issues to thread stack allocationJoel Sherrill1996-04-241-0/+14
| | | | routine.
* thread.c: added support for optional user provided stack allocatorJoel Sherrill1996-04-221-8/+80
| | | | wkspace.c: made initialization routine a regular subroutine
* *** empty log message ***Joel Sherrill1996-03-211-4/+4
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-211-5/+105
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* removed arguments from _Thread_Start_multitaskingJoel Sherrill1996-02-141-12/+10
* white space problemJoel Sherrill1996-02-141-1/+0
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-131-1/+6
| | | | in each thread which must be set when the post switch extension is to be run.
* SPARC port passes all testsJoel Sherrill1995-10-301-1/+5
* posix support initially addedJoel Sherrill1995-09-261-10/+10
* More file movementJoel Sherrill1995-09-211-1/+0
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-191-0/+1
| | | | | Thread_Close fixed to avoid returning FP context area when one was not allocated at initialization time.
* Initial attempt at building HP PA-RISC using Solaris hosted tools.Joel Sherrill1995-09-121-0/+3
| | | | Changed back to Newlib for Solaris UNIX simulator.
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-131/+106
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-23/+293
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-20/+27
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-5/+7
* Fixed missing RCS IdsJoel Sherrill1995-08-221-1/+1
* + Added object type field to object id.Joel Sherrill1995-08-181-0/+1
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-5/+5
* Switched to events for mp receive server and eliminated the specialJoel Sherrill1995-07-311-1/+2
| | | | blocking mechanism for it.
* changed release number to 3.2.0Joel Sherrill1995-06-041-9/+10
* Initial revisionJoel Sherrill1995-05-111-0/+805
