* | score: Fix for RTEMS_DEBUG | Sebastian Huber | 2016-07-25 | 1 | -0/+1 |
* | score: Rename _ISR_Disable_without_giant() | Sebastian Huber | 2016-05-20 | 1 | -2/+2 |
| | | | | | | | | | Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename _ISR_Enable_without_giant() into _ISR_Local_enable(). This is a preparation to remove the Giant lock. Update #2555. | ||||
* | score: Add _SMP_Before_multitasking_action() | Sebastian Huber | 2016-03-04 | 1 | -2/+2 |
| | | | | | | | | | The use case for this is the Cortex-A9 MPCore which has per-processor registers (only accessible by a particular processor) for the global timer used by the clock driver. This might be useful for other drivers as well. Update #2554. | ||||
* | score: Refactor SMP cache manager support | Sebastian Huber | 2015-04-20 | 1 | -0/+141 |
