brains GmbH.
Updates #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3059.
In SMP configurations, add a red-black tree node to Scheduler_Node to
enable an EDF scheduler implementation.
Update #3056.
Update #2797.
The CPU time used of a thread was previously maintained per-processor
mostly during _Thread_Dispatch(). However, on SMP configurations the
actual processor of a thread is difficult to figure out since thread
dispatching is a highly asynchronous process (e.g. via inter-processor
interrupts). Only the intended processor of a thread is known to the
scheduler easily. Do the CPU usage accounting during thread heir
updates in the context of the scheduler operations. Provide the
function _Thread_Get_CPU_time_used() to get the CPU usage of a thread
using proper locks to get a consistent value.
Close #2627.
The following scheduler operations return a thread in need for help
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
Add a new ask for help scheduler operation. This operation is used by
_Scheduler_Ask_for_help() to help threads in need for help returned by
the operations mentioned above. This operation is also used by
_Scheduler_Thread_change_resource_root() in case the root of a resource
sub-tree changes. A use case is the ownership change of a resource.
In case it is not possible to schedule a thread in need for help, then
the corresponding scheduler node will be placed into the set of ready
scheduler nodes of the scheduler instance. Once a state change from
ready to scheduled happens for this scheduler node it may be used to
schedule the thread in need for help.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
Add a chain node to the scheduler node to decouple the thread and
scheduler nodes. It is now possible to enqueue a thread in a thread
wait queue and use its scheduler node at the same for other threads,
e.g. a resouce owner.
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
Rename _Scheduler_simple_smp_Start_idle() to
_Scheduler_SMP_Start_idle().
