Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of schedulersimple.h and
schedulersimple.inl into new header file schedulersimpleimpl.h. The
schedulersimple.h contains now only the application visible API.
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
* score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleyield.c: Fix violations of naming
convention.
PR 1743/cpu
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple Priority Scheduler as complement to existing Deterministic
Priority Scheduler. This scheduler serves both as an example and as a
lighter weight implementation for smaller systems.
* score/include/rtems/score/schedulersimple.h,
score/src/schedulersimple.c, score/src/schedulersimpleblock.c,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c:
New files.
