comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
* score/include/rtems/score/schedulersimple.h,
score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleunblock.c: Correct names as pointed out by
Gedare.
PR 1743/cpu
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple Priority Scheduler as complement to existing Deterministic
Priority Scheduler. This scheduler serves both as an example and as a
lighter weight implementation for smaller systems.
score/src/schedulersimple.c, score/src/schedulersimpleblock.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c:
New files.
