path: root/cpukit/score/src/schedulersimpleblock.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Pass scheduler node to block operationSebastian Huber2016-11-021-1/+3
| | | | | | Changed for consistency with other scheduler operations. Update #2556.
* score: Static scheduler configurationSebastian Huber2014-04-151-2/+2
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* score: Add scheduler control to scheduler opsSebastian Huber2014-04-041-3/+5
| | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling.
* score: PR2136: Fix _Thread_Change_priority()Sebastian Huber2013-08-201-9/+6
| | | | | | | | | | | | | | | Add call to _Scheduler_Schedule() in missing path after _Thread_Set_transient() in _Thread_Change_priority(). See also sptests/spintrcritical19. Add thread parameter to _Scheduler_Schedule(). This parameter is currently unused but may be used in future SMP schedulers. Do heir selection in _Scheduler_Schedule(). Use _Scheduler_Update_heir() for this in the particular scheduler implementation. Add and use _Scheduler_Generic_block().
* score: Create thread implementation headerSebastian Huber2013-07-261-8/+1
| | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files.
* score misc: Clean up Doxygen #2 (GCI 2012)Christopher Kerl2012-11-281-2/+8
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-161-0/+39
PR 1743/cpu * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Simple Priority Scheduler as complement to existing Deterministic Priority Scheduler. This scheduler serves both as an example and as a lighter weight implementation for smaller systems. * score/include/rtems/score/schedulersimple.h, score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimple.c, score/src/schedulersimpleblock.c, score/src/schedulersimpleenqueue.c, score/src/schedulersimpleenqueuefirst.c, score/src/schedulersimpleextract.c, score/src/schedulersimplereadyqueueenqueue.c, score/src/schedulersimplereadyqueueenqueuefirst.c, score/src/schedulersimpleschedule.c, score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c: New files.
