* | score misc: Score misc: Clean up Doxygen #6 (GCI 2012) | Christopher Kerl | 2012-11-29 | 1 | -27/+8 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7976215 | ||||
* | Remove white-spaces. | Ralf Corsepius | 2011-05-24 | 1 | -5/+5 |
* | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 2011-03-16 | 1 | -0/+84 |
PR 1743/cpu * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Simple Priority Scheduler as complement to existing Deterministic Priority Scheduler. This scheduler serves both as an example and as a lighter weight implementation for smaller systems. * score/include/rtems/score/schedulersimple.h, score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimple.c, score/src/schedulersimpleblock.c, score/src/schedulersimpleenqueue.c, score/src/schedulersimpleenqueuefirst.c, score/src/schedulersimpleextract.c, score/src/schedulersimplereadyqueueenqueue.c, score/src/schedulersimplereadyqueueenqueuefirst.c, score/src/schedulersimpleschedule.c, score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c: New files. |
