* | score: Create prioritybitmap implementation header | Sebastian Huber | 2013-07-26 | 1 | -6/+1 |
| | | | | | | | | Move implementation specific parts of prioritybitmap.h and prioritybitmap.inl into new header file prioritybitmapimpl.h. The prioritybitmap.h contains now only the application visible API. Move content of bitfield.h into prioritybitmapimpl.h. | ||||
* | score misc: Clean up Doxygen (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -2/+7 |
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208 | ||||
* | Remove white-spaces. | Ralf Corsepius | 2011-05-24 | 1 | -3/+3 |
* | 2011-02-27 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 2011-02-28 | 1 | -1/+0 |
| | | | | | | * score/include/rtems/score/schedulerpriority.h, score/src/schedulerpriority.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityupdate.c: Formatting. | ||||
* | 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-18 | 1 | -0/+43 |
* sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/thread.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadsetpriority.c, score/src/threadsettransient.c: Significant clean up on Scheduler Plugin Interface. Names were shortened. Missing operations added. Many scheduler files had unneeded includes removed. Made pointer to scheduler information in Thread_Control and Scheduler_Control a void * pointer because the thread and scheduler wrapper should be unaware of scheduler types AND this is broken for user provided schedulers. * score/src/schedulerpriorityallocate.c, score/src/schedulerpriorityenqueue.c, score/src/schedulerpriorityenqueuefirst.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityfree.c, score/src/schedulerpriorityupdate.c: New files. * score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c: Removed. |
