* | score misc: Clean up Doxygen #3 (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -0/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7982215 | ||||
* | 2011-09-01 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-01 | 1 | -0/+27 |
PR 1895/cpukit * rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemonperiod.c, sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/schedulersimple.h, score/include/rtems/score/schedulersimplesmp.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/coremutexseize.c: Add priority_compare and release_job hooks interfaces to scheduler interface. * score/src/schedulerpriorityprioritycompare.c, score/src/schedulerpriorityreleasejob.c: New files. |
