* | score: Create schedulerpriority impl header | Sebastian Huber | 2013-07-26 | 1 | -4/+1 |
| | | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map. | ||||
* | score misc: Clean up Doxygen #3 (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -0/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7982215 | ||||
* | 2011-09-01 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-01 | 1 | -0/+27 |
PR 1895/cpukit * rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemonperiod.c, sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/schedulersimple.h, score/include/rtems/score/schedulersimplesmp.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/coremutexseize.c: Add priority_compare and release_job hooks interfaces to scheduler interface. * score/src/schedulerpriorityprioritycompare.c, score/src/schedulerpriorityreleasejob.c: New files. |
