* | score: Add scheduler control to scheduler ops | Sebastian Huber | 2014-04-04 | 1 | -3/+5 |
| | | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling. | ||||
* | score: Move priority bit map to scheduler instance | Sebastian Huber | 2014-04-03 | 1 | -1/+6 |
| | | | | | | Delete global variables _Priority_Major_bit_map and _Priority_Bit_map. This makes it possible to use multiple priority scheduler instances for example with clustered/partitioned scheduling on SMP. | ||||
* | score: Create schedulerpriority impl header | Sebastian Huber | 2013-07-26 | 1 | -4/+1 |
| | | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map. | ||||
* | score misc: Score misc: Clean up Doxygen #7 (GCI 2012) | Alex Ivanov | 2012-11-29 | 1 | -0/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214 | ||||
* | Remove white-spaces. | Ralf Corsepius | 2011-05-24 | 1 | -1/+1 |
* | 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-18 | 1 | -0/+27 |
* sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/thread.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadsetpriority.c, score/src/threadsettransient.c: Significant clean up on Scheduler Plugin Interface. Names were shortened. Missing operations added. Many scheduler files had unneeded includes removed. Made pointer to scheduler information in Thread_Control and Scheduler_Control a void * pointer because the thread and scheduler wrapper should be unaware of scheduler types AND this is broken for user provided schedulers. * score/src/schedulerpriorityallocate.c, score/src/schedulerpriorityenqueue.c, score/src/schedulerpriorityenqueuefirst.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityfree.c, score/src/schedulerpriorityupdate.c: New files. * score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c: Removed. |
