* | score: Add scheduler control to scheduler ops | Sebastian Huber | 2014-04-04 | 1 | -1/+4 |
| | | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling. | ||||
* | score: _Scheduler_priority_Ready_queue_initialize() | Sebastian Huber | 2013-08-20 | 1 | -0/+1 |
| | | | | Move workspace allocation to _Scheduler_priority_Initialize(). | ||||
* | score: Add _Scheduler_priority_Get_scheduler_info | Sebastian Huber | 2013-08-20 | 1 | -9/+5 |
| | | | | Add and use _Scheduler_priority_Get_scheduler_info(). | ||||
* | score misc: Score misc: Clean up Doxygen #7 (GCI 2012) | Alex Ivanov | 2012-11-29 | 1 | -2/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214 | ||||
* | 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-18 | 1 | -0/+35 |
* sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/thread.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadsetpriority.c, score/src/threadsettransient.c: Significant clean up on Scheduler Plugin Interface. Names were shortened. Missing operations added. Many scheduler files had unneeded includes removed. Made pointer to scheduler information in Thread_Control and Scheduler_Control a void * pointer because the thread and scheduler wrapper should be unaware of scheduler types AND this is broken for user provided schedulers. * score/src/schedulerpriorityallocate.c, score/src/schedulerpriorityenqueue.c, score/src/schedulerpriorityenqueuefirst.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityfree.c, score/src/schedulerpriorityupdate.c: New files. * score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c: Removed. |
