path: root/cpukit/score/src/schedulerpriority.c (follow)
* score: Create schedulerpriority impl headerSebastian Huber2013-07-261-5/+1
| | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map.
* score misc: Score misc: Clean up Doxygen #11 (GCI 2012)Daniel Georgiev2012-12-011-1/+6
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013204
* 2011-02-27 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-02-281-1/+1
| | | | | | * score/include/rtems/score/schedulerpriority.h, score/src/schedulerpriority.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityupdate.c: Formatting.
* 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-181-5/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sapi/include/confdefs.h, score/Makefile.am, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/thread.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadsetpriority.c, score/src/threadsettransient.c: Significant clean up on Scheduler Plugin Interface. Names were shortened. Missing operations added. Many scheduler files had unneeded includes removed. Made pointer to scheduler information in Thread_Control and Scheduler_Control a void * pointer because the thread and scheduler wrapper should be unaware of scheduler types AND this is broken for user provided schedulers. * score/src/schedulerpriorityallocate.c, score/src/schedulerpriorityenqueue.c, score/src/schedulerpriorityenqueuefirst.c, score/src/schedulerpriorityextract.c, score/src/schedulerpriorityfree.c, score/src/schedulerpriorityupdate.c: New files. * score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* 2011-02-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-171-32/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | * sapi/include/confdefs.h, sapi/include/rtems/config.h, score/include/rtems/score/scheduler.h, score/include/rtems/score/schedulerpriority.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/scheduler.c, score/src/schedulerpriority.c, score/src/schedulerpriorityblock.c, score/src/schedulerpriorityschedule.c, score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadready.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the pluggable scheduler interface. Its configuration made a table of available schedulers and set a pointer to one of the. This was heavy handed since you can only use one scheduler in an application. This configuration mechanism resulted in a scheduler pointer being passed around when you could put all scheduler configuration in an initialized structure.
* 2010-11-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-11-251-7/+7
| | | | | | | | | | | | * sapi/include/confdefs.h, score/include/rtems/score/scheduler.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl, score/src/schedulerpriority.c, score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerprioritythreadschedulerupdate.c, score/src/schedulerpriorityyield.c: Added attribute unused. Renamed types and fields to follow the Score naming conventions.
* 2010-11-24 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-11-241-0/+66
PR 1647/cpukit * posix/src/nanosleep.c, posix/src/sched_yield.c, rtems/src/taskwakeafter.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/prioritybitmap.h, score/include/rtems/score/thread.h, score/inline/rtems/score/thread.inl, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadinitialize.c, score/src/threadready.c, score/src/threadresume.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c: Refactor scheduler out of thread handler to facilitate alternate scheduler implementations. * score/src/threadyieldprocessor.c: Removed. * score/src/schedulerprioritythreadschedulerupdate.c, score/src/schedulerprioritythreadschedulerfree.c, score/src/schedulerpriorityblock.c, score/src/scheduler.c, score/src/schedulerprioritythreadschedulerallocate.c, score/src/schedulerpriorityunblock.c, score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c, score/include/rtems/score/schedulerpriority.h, score/include/rtems/score/scheduler.h, score/inline/rtems/score/scheduler.inl, score/inline/rtems/score/schedulerpriority.inl: New files.
