Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Provide the scheduler node to initialize or destroy to the corresponding
operations. This makes it possible to have more than one scheduler node
per thread.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
Use priority maximum of scheduler instance. This avoids a potential
memory corruption on SMP configurations.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
Delete _Priority_bit_map_Handler_initialization() and rely on BSS
initialization. Move definition of _Priority_Major_bit_map and
_Priority_Bit_map to separate file. Move definition of __log2table also
to this file.
Move workspace allocation to _Scheduler_priority_Initialize().
Move implementation specific parts of schedulerpriority.h and
schedulerpriority.inl into new header file schedulerpriorityimpl.h. The
schedulerpriority.h contains now only the application visible API.
Add missing includes. Remove superfluous includes.
Move declaration of _Priority_Bit_map to prioritybitmap.inl since this
variable is used only here.
Remove second declaration of _Priority_Major_bit_map.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
* score/include/rtems/score/schedulerpriority.h,
score/src/schedulerpriority.c, score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityupdate.c: Formatting.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/scheduler.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* sapi/include/confdefs.h, score/include/rtems/score/scheduler.h,
score/src/schedulerpriorityyield.c: Added attribute unused. Renamed
types and fields to follow the Score naming conventions.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
