* | scheduler: Specify thread of yield operation | Sebastian Huber | 2013-06-14 | 1 | -7/+6 |
| | | | | | | The yielding thread of the yield operation is now specified by a parameter. The tick operation may be performed for each executing thread in a SMP configuration. | ||||
* | score misc: Score misc: Clean up Doxygen #10 (GCI 2012) | Christopher Kerl | 2012-12-01 | 1 | -0/+8 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7983216 | ||||
* | 2011-09-20 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-20 | 1 | -22/+11 |
| | | | | | | | PR 1916/testing * rtems/src/ratemondelete.c, score/src/schedulercbsreleasejob.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: Rework to improve coverage. | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 1 | -0/+57 |
PR 1896/cpukit * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Earliest Deadline First (EDF) Scheduling Algorithm implementation. * score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c, score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c, score/src/scheduleredfenqueue.c, score/src/scheduleredfenqueuefirst.c, score/src/scheduleredfextract.c, score/src/scheduleredffree.c, score/src/scheduleredfprioritycompare.c, score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c, score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: New files. |
