Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Interrupts are disabled by the caller _Thread_Change_priority() or
_Thread_Set_transient() or directly in the scheduler operation. Thus
there is no need to use protected variants.
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
PR 1916/testing
* rtems/src/ratemondelete.c, score/src/schedulercbsreleasejob.c,
score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: Rework
to improve coverage.
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
