Move the writes to Thread_Control::current_priority and
Thread_Control::real_priority into _Thread_Change_priority() under the
protection of the thread lock. Add a filter function to
_Thread_Change_priority() to enable specialized variants.
Avoid race conditions during a thread priority restore with the new
Thread_Control::priority_restore_hint for an important average case
optimizations used by priority inheritance mutexes.
Update #2273.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
