path: root/cpukit/score/src/scheduleredfprioritycompare.c (follow)
* score: Create watchdog implementation headerSebastian Huber2013-07-221-0/+1
| | | | | | Move implementation specific parts of watchdog.h and watchdog.inl into new header file watchdogimpl.h. The watchdog.h contains now only the application visible API.
* score misc: Clean up Doxygen #2 (GCI 2012)Christopher Kerl2012-11-281-0/+8
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* 2011-09-11 Petr Benes <benesp16@fel.cvut.cz>Joel Sherrill2011-09-111-0/+40
PR 1896/cpukit * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Earliest Deadline First (EDF) Scheduling Algorithm implementation. * score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c, score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c, score/src/scheduleredfenqueue.c, score/src/scheduleredfenqueuefirst.c, score/src/scheduleredfextract.c, score/src/scheduleredffree.c, score/src/scheduleredfprioritycompare.c, score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c, score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: New files.
