* | score: Static scheduler configuration | Sebastian Huber | 2014-04-15 | 1 | -2/+2 |
| | | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP. | ||||
* | score: Add scheduler control to scheduler ops | Sebastian Huber | 2014-04-04 | 1 | -1/+2 |
| | | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling. | ||||
* | score misc: Score misc: Clean up Doxygen #10 (GCI 2012) | Christopher Kerl | 2012-12-01 | 1 | -0/+8 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7983216 | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 1 | -0/+25 |
PR 1896/cpukit * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Earliest Deadline First (EDF) Scheduling Algorithm implementation. * score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c, score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c, score/src/scheduleredfenqueue.c, score/src/scheduleredfenqueuefirst.c, score/src/scheduleredfextract.c, score/src/scheduleredffree.c, score/src/scheduleredfprioritycompare.c, score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c, score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: New files. |
