* | scheduler/EDF: Use unprotected insert and extract | Sebastian Huber | 2013-11-21 | 1 | -1/+1 |
| | | | | | | Interrupts are disabled by the caller _Thread_Change_priority() or _Thread_Set_transient() or directly in the scheduler operation. Thus there is no need to use protected variants. | ||||
* | score misc: Clean up Doxygen (GCI 2012) | Alex Ivanov | 2012-11-28 | 1 | -0/+7 |
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208 | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 1 | -0/+31 |
PR 1896/cpukit * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Earliest Deadline First (EDF) Scheduling Algorithm implementation. * score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c, score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c, score/src/scheduleredfenqueue.c, score/src/scheduleredfenqueuefirst.c, score/src/scheduleredfextract.c, score/src/scheduleredffree.c, score/src/scheduleredfprioritycompare.c, score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c, score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: New files. |
