Use inline red-black tree insert. Do not use shifting priorities since
this is not supported by the thread queues. Due to the 32-bit
Priority_Control this currently limits the uptime to 49days with a 1ms
clock tick.
Update #2173.
By convention, thread priorities must be integers in RTEMS. Smaller
values represent more important threads.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Move implementation specific parts of scheduler.h and scheduler.inl into
new header file schedulerimpl.h. The scheduler.h contains now only the
application visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
* rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension,
_RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension,
_RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension
static.
* score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function
static.
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
