* | Score misc: Clean up Doxygen #8 (GCI 2012) | Mathew Kallada | 2012-11-29 | 1 | -0/+7 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7970221 | ||||
* | score/scheduleredf: Simplify and fix warning | Sebastian Huber | 2012-03-30 | 1 | -3/+3 |
* | 2011-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-02 | 1 | -1/+1 |
| | | | | | | | | | * rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension, _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, _RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension static. * score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function static. | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 1 | -0/+49 |
PR 1896/cpukit * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Earliest Deadline First (EDF) Scheduling Algorithm implementation. * score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c, score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c, score/src/scheduleredfenqueue.c, score/src/scheduleredfenqueuefirst.c, score/src/scheduleredfextract.c, score/src/scheduleredffree.c, score/src/scheduleredfprioritycompare.c, score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c, score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: New files. |
