path: root/cpukit/score/src/schedulerdefaulttick.c (follow)
* Remove use ticks for statistics configure option.Joel Sherrill2015-06-151-7/+0
| | | | | | | | | | This was obsolete and broken based upon recent time keeping changes. Thie build option was previously enabled by adding USE_TICKS_FOR_STATISTICS=1 to the configure command line. This propagated into the code as preprocessor conditionals using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
* score: PR2181: Add _Thread_Yield()Sebastian Huber2014-06-121-1/+3
| | | | | | | | | | | | | | | | | | | The _Scheduler_Yield() was called by the executing thread with thread dispatching disabled and interrupts enabled. The rtems_task_suspend() is explicitly allowed in ISRs: http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR Unlike the other scheduler operations the locking was performed inside the operation. This lead to the following race condition. Suppose a ISR suspends the executing thread right before the yield scheduler operation. Now the executing thread is not longer in the set of ready threads. The typical scheduler operations did not check the thread state and will now extract the thread again and enqueue it. This corrupted data structures. Add _Thread_Yield() and do the scheduler yield operation with interrupts disabled. This has a negligible effect on the interrupt latency.
* score: Add clustered/partitioned schedulingSebastian Huber2014-04-151-13/+1
| | | | | | | | | | | | | | | Clustered/partitioned scheduling helps to control the worst-case latencies in the system. The goal is to reduce the amount of shared state in the system and thus prevention of lock contention. Modern multi-processor systems tend to have several layers of data and instruction caches. With clustered/partitioned scheduling it is possible to honour the cache topology of a system and thus avoid expensive cache synchronization traffic. We have clustered scheduling in case the set of processors of a system is partitioned into non-empty pairwise-disjoint subsets. These subsets are called clusters. Clusters with a cardinality of one are partitions. Each cluster is owned by exactly one scheduler instance.
* score: Static scheduler configurationSebastian Huber2014-04-151-3/+3
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* score: Delete _Thread_Ticks_per_timesliceSebastian Huber2014-04-071-1/+3
| | | | Use the Configuration instead.
* score: Add scheduler control to scheduler opsSebastian Huber2014-04-041-4/+7
| | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling.
* smp: Add and use _Per_CPU_Get()Sebastian Huber2013-07-301-3/+3
| | | | | | Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add _Per_CPU_Send_interrupt(). This avoids direct access of _Per_CPU_Information.
* score: Create thread implementation headerSebastian Huber2013-07-261-1/+1
| | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files.
* score: Create scheduler implementation headerSebastian Huber2013-07-261-2/+1
| | | | | | Move implementation specific parts of scheduler.h and scheduler.inl into new header file schedulerimpl.h. The scheduler.h contains now only the application visible API.
* scheduler: Add and use _Scheduler_default_Tick()Sebastian Huber2013-06-141-0/+93
Delete _Scheduler_priority_Tick(). Use _SMP_Get_processor_count() for default tick operation. Delete _Scheduler_simple_smp_Tick().
