Updates #3053.
Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Remove the scheduler parameter from most high level scheduler operations
like
- _Scheduler_Block(),
- _Scheduler_Unblock(),
- _Scheduler_Change_priority(),
- _Scheduler_Update_priority(),
- _Scheduler_Release_job(), and
- _Scheduler_Yield().
This simplifies the scheduler operations usage.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Move implementation specific parts of scheduler.h and scheduler.inl into
new header file schedulerimpl.h. The scheduler.h contains now only the
application visible API.
Add and use _Scheduler_Start_idle().
