path: root/cpukit/score/src/schedulerdefaultnodeinit.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Rework thread priority managementSebastian Huber2016-09-211-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | Add priority nodes which contribute to the overall thread priority. The actual priority of a thread is now an aggregation of priority nodes. The thread priority aggregation for the home scheduler instance of a thread consists of at least one priority node, which is normally the real priority of the thread. The locking protocols (e.g. priority ceiling and priority inheritance), rate-monotonic period objects and the POSIX sporadic server add, change and remove priority nodes. A thread changes its priority now immediately, e.g. priority changes are not deferred until the thread releases its last resource. Replace the _Thread_Change_priority() function with * _Thread_Priority_perform_actions(), * _Thread_Priority_add(), * _Thread_Priority_remove(), * _Thread_Priority_change(), and * _Thread_Priority_update(). Update #2412. Update #2556.
* score: Change scheduler node init and destroySebastian Huber2016-07-011-2/+1
| | | | | | Provide the scheduler node to initialize or destroy to the corresponding operations. This makes it possible to have more than one scheduler node per thread.
* score: Add thread priority to scheduler nodesSebastian Huber2016-06-221-2/+3
| | | | | | | | | | | | | | | | | | The thread priority is manifest in two independent areas. One area is the user visible thread priority along with a potential thread queue. The other is the scheduler. Currently, a thread priority update via _Thread_Change_priority() first updates the user visble thread priority and the thread queue, then the scheduler is notified if necessary. The priority is passed to the scheduler via a local variable. A generation counter ensures that the scheduler discards out-of-date priorities. This use of a local variable ties the update in these two areas close together. For later enhancements and the OMIP locking protocol implementation we need more flexibility. Add a thread priority information block to Scheduler_Node and synchronize priority value updates via a sequence lock on SMP configurations. Update #2556.
* score: Implement scheduler helping protocolSebastian Huber2014-07-091-2/+5
| | | | | | | | | | | | | | | | | | | | | | | | | The following scheduler operations return a thread in need for help - unblock, - change priority, and - yield. A thread in need for help is a thread that encounters a scheduler state change from scheduled to ready or a thread that cannot be scheduled in an unblock operation. Such a thread can ask threads which depend on resources owned by this thread for help. Add a new ask for help scheduler operation. This operation is used by _Scheduler_Ask_for_help() to help threads in need for help returned by the operations mentioned above. This operation is also used by _Scheduler_Thread_change_resource_root() in case the root of a resource sub-tree changes. A use case is the ownership change of a resource. In case it is not possible to schedule a thread in need for help, then the corresponding scheduler node will be placed into the set of ready scheduler nodes of the scheduler instance. Once a state change from ready to scheduled happens for this scheduler node it may be used to schedule the thread in need for help.
* score: Replace _Scheduler_Allocate/Free()Sebastian Huber2014-06-041-0/+31
Replace _Scheduler_Allocate() with _Scheduler_Node_initialize(). Remove the return status and thus the node initialization must be always successful. Rename _Scheduler_Free() to _Scheduler_Node_destroy().
