path: root/cpukit/score/src/schedulerdefaultmappriority.c (follow)
* score: Optimize scheduler priority updatesSebastian Huber2017-11-201-3/+11
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Thread priority changes may append or prepend the thread to its priority group on the scheduler ready queue. Previously, a separate priority value and a prepend-it flag in the scheduler node were used to propagate a priority change to the scheduler. Now, use an append-it bit in the priority control and reduce the plain priority value to 63 bits. This change leads to a significant code size reduction (about 25%) of the SMP schedulers. The negligible increase of the standard priority scheduler is due to some additional shift operations (SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()). Before: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o After: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
* score: Introduce map priority scheduler operationSebastian Huber2016-06-221-0/+21
Introduce map/unmap priority scheduler operations to map thread priority values from/to the user domain to/from the scheduler domain. Use the map priority operation to validate the thread priority. The EDF schedulers use this new operation to distinguish between normal priorities and priorities obtain through a job release. Update #2173. Update #2556.
