In addition protect scheduler of thread by thread state lock. Enables
use of scheduler per-instance locks.
Update #2555.
This is currently a global lock for all scheduler instances. It should
get replaced with one lock per scheduler instance in the future.
Update #2273.
Previously, the _Thread_Heir was updated unconditionally in case a new
heir was determined. The _Thread_Dispatch_necessary was only updated in
case the executing thread was preemptible or an internal thread was
unblocked. Change this to update the _Thread_Heir and
_Thread_Dispatch_necessary only in case the currently selected heir
thread is preemptible or a dispatch is forced. Move the schedule
decision into the change priority operation and use the schedule
operation only in rtems_task_mode() in case preemption is enabled or an
ASR dispatch is necessary. This is a behaviour change. Previously, the
RTEMS_NO_PREEMPT also prevented signal delivery in certain cases (not
always). Now, signal delivery is no longer influenced by
RTEMS_NO_PREEMPT. Since the currently selected heir thread is used to
determine if a new heir is chosen, non-preemptible heir threads
currently not executing now prevent a new heir. This may have an
application impact, see change test tm04. Document this change in sp04.
Update #2273.
Return a thread in need for help for the following scheduler operations
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of scheduler.h and scheduler.inl into
new header file schedulerimpl.h. The scheduler.h contains now only the
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbsattachthread.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
