Use common phrases for the file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
* score/src/schedulercbsattachthread.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbssetparameters.c:
Remove checks for server_id < 0 (server_id is unsigned).
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
