Uniformly use *_Get() to get an object by identifier with a lock
context.
Update #2555.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* score/src/schedulercbsattachthread.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbssetparameters.c:
Remove checks for server_id < 0 (server_id is unsigned).
PR 1942/cpukit:
* score/src/schedulercbsdetachthread.c: Move initialization of var
"sched_info" down (Avoid it being used uninitialized).
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
