path: root/cpukit/score/src/schedulercbsdestroyserver.c (follow)
* score misc: Clean up Doxygen #2 (GCI 2012)Christopher Kerl2012-11-281-0/+8
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7986213
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-061-1/+1
| | | | | | | | | | | | * score/src/schedulercbsattachthread.c, score/src/schedulercbsdestroyserver.c, score/src/schedulercbsdetachthread.c, score/src/schedulercbsgetapprovedbudget.c, score/src/schedulercbsgetexecutiontime.c, score/src/schedulercbsgetparameters.c, score/src/schedulercbsgetremainingbudget.c, score/src/schedulercbssetparameters.c: Remove checks for server_id < 0 (server_id is unsigned).
* 2011-09-15 Petr Benes <benesp16@fel.cvut.cz>Joel Sherrill2011-09-151-0/+40
PR 1906/cpukit * sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add the CBS (Constant Bandwidth Server) scheduler. This is a complex scheduling policy built atop of the EDF scheduler. Unlike other schedulers, this one provides a user API and handles not only deadlines of tasks but also claimed budget per period. The main aim of the scheduler is isolation of tasks so that each task is guaranteed to meet all deadlines regardless of how other tasks behave. * sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl, score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c, score/src/schedulercbsattachthread.c, score/src/schedulercbscleanup.c, score/src/schedulercbscreateserver.c, score/src/schedulercbsdestroyserver.c, score/src/schedulercbsdetachthread.c, score/src/schedulercbsgetapprovedbudget.c, score/src/schedulercbsgetexecutiontime.c, score/src/schedulercbsgetparameters.c, score/src/schedulercbsgetremainingbudget.c, score/src/schedulercbsgetserverid.c, score/src/schedulercbsreleasejob.c, score/src/schedulercbssetparameters.c, score/src/schedulercbsunblock.c: New files.
