path: root/cpukit/score/src/schedulercbscreateserver.c (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Move SCHEDULER_EDF_PRIO_MSBSebastian Huber2016-06-241-0/+1
| | | | This is an implementation detail of the EDF scheduler.
* score: Static scheduler configurationSebastian Huber2014-04-151-8/+3
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* score: Create schedulerpriority impl headerSebastian Huber2013-07-261-3/+1
| | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map.
* score misc: Clean up Doxygen #3 (GCI 2012)Alex Ivanov2012-11-281-0/+7
| | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7982215
* 2011-09-15 Petr Benes <benesp16@fel.cvut.cz>Joel Sherrill2011-09-151-0/+55
PR 1906/cpukit * sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add the CBS (Constant Bandwidth Server) scheduler. This is a complex scheduling policy built atop of the EDF scheduler. Unlike other schedulers, this one provides a user API and handles not only deadlines of tasks but also claimed budget per period. The main aim of the scheduler is isolation of tasks so that each task is guaranteed to meet all deadlines regardless of how other tasks behave. * sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl, score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c, score/src/schedulercbsattachthread.c, score/src/schedulercbscleanup.c, score/src/schedulercbscreateserver.c, score/src/schedulercbsdestroyserver.c, score/src/schedulercbsdetachthread.c, score/src/schedulercbsgetapprovedbudget.c, score/src/schedulercbsgetexecutiontime.c, score/src/schedulercbsgetparameters.c, score/src/schedulercbsgetremainingbudget.c, score/src/schedulercbsgetserverid.c, score/src/schedulercbsreleasejob.c, score/src/schedulercbssetparameters.c, score/src/schedulercbsunblock.c: New files.
