comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbsattachthread.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
PR 1896/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Earliest Deadline First (EDF) Scheduling Algorithm implementation.
* score/include/rtems/score/scheduleredf.h, score/src/scheduleredf.c,
score/src/scheduleredfallocate.c, score/src/scheduleredfblock.c,
score/src/scheduleredfenqueue.c,
score/src/scheduleredfenqueuefirst.c,
score/src/scheduleredfextract.c, score/src/scheduleredffree.c,
score/src/scheduleredfprioritycompare.c,
score/src/scheduleredfreleasejob.c, score/src/scheduleredfschedule.c,
score/src/scheduleredfunblock.c, score/src/scheduleredfupdate.c,
score/src/scheduleredfyield.c: New files.
score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* sapi/include/confdefs.h, score/include/rtems/score/scheduler.h,
score/src/schedulerpriorityyield.c: Added attribute unused. Renamed
types and fields to follow the Score naming conventions.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
